Hi!
I got an Anker PowerPort 5+ (the one with 1 USB-C PD), and when I connect different devices to the USB-A ports, they charge up to 100% but they never stop charging for some reason. With any other USB charger, the devices shut down when they’re fully charged stop draining power from the charger, and leds change to signal fully charged (or the icon of the plug instead of the lightning appears in the iphone). But with this wall charger, the devices never reach that fully charged state.
Is this normal behaviour or do I have a faulty unit?
Thanks!
Update: Alongside the PowerPort 5+ I bought a PowerCore+ 26800, and I am seeing the exact same behaviour with the powercore: USB devices charge perfectly fast, they just never stop charging.
I have tested this with 4 devices:
iPhone 6s+
Apple Watch 2
Jbl Bluetooth speaker
Sony MP3 player
And with 3 different original Apple usbA-lightning cables and 2 different UsbA-microUSB. I have also tested it in 2 different outlets.
With every combination the result is the same: the gadgets charge perfectly fast from both the PowerCore and the PowerPort, but never finish charging. As soon as I connect them to any other non Anker USB charger or powerbank, the battery/plug icon appears, and the device stops charging as it should.
Any ideas? It is impossible that both units are defective so I guess this is the Anker standard behaviour? Would someone be able to confirm?
Thanks a lot!
