i am thinking about buying a PowerCore+ 26800 as it supports charging with quick charge 3.0. i plan NOT to use the provided charger (PowerPort+ 1) but another one (with quick charge 3.0 ports) that i already own so i can recharge the powerbank at the same time as i recharge other devices. as my charger only has USB-A outputs i cant use the USB-C cable that comes with the powerbank to charge it.
now to the question:
*** do i need a special USB-A to USB-C cable to charge the “PowerCore+ 26800” via quick charge 3.0 or does any USB-A to USB-C cable support that?**
*** if so can you recommend an anker cable?**
thanks for your help
