PowerCore+ 26800 Powerport Suggestion
I bought a power bank ‘PowerCore+ 26800’, which wall chargers will be great for me ??
May I should buy PowerPort+ 1 with Quick Charge 3.0, this ??
Or this one ??
My phone model is - HTC One A9
Thank you in advance.
Arif
Either or plug you posted will work to fast charge the power bank provided you use the QC port on the dual plug and not the power IQ port. If you are only charging the battery pack then use the single, but if you want to charge multiple devices get the dual
I would choose the PowerPort 2 Ports :ok_hand:
I’d go with Daisy as you can never have too many ports!
I know this is a bit more expensive, but I think it’s totally worth it. I have one of these by my bed and I love it. The two QC 3.0 ports are awesome:
It’s also small enough to be portable. With a single 2-prong plug you can plug in anywhere, even old sockets like in my “vintage” house :slight_smile:
As long you will not loose the overview of all your ports! :joy:
If I have too many ports I might become a portaholic @fhassm :wink::joy:
Remember those “Old kings of England” had ports all over the world!
But “port” could mean “Vinho do Porto” as well! :joy:
@fhassm instead of “warts and all” it’ll be “ports and all” :stuck_out_tongue_winking_eye:
Powerport 2 charger with two ports is what I use.
