Powercore+ 26800 mAh not charging but the lights are keep on blinking (all lights)
My powercore+ is not charging properly. I used to have a powercore II 20000 mAh. I tried charging it for about 7 hours now and yet it is still not charging. Any recommendations on how to fix this issue? Thanks guys. Btw I just bought it 2 weeks ago.
What charger are you using and what are the specs of that charger? Also your title says 26800, but your post says 20000 so which is it?
Hi. I’m using samsung as the head charger and the anker wire. I used to have the 20000mah before but I bought the 26800 2 weeks ago and now it is not charging.
The Samsung charger is not sufficient to charge this batterypack, it reverts to the lowest power output and can take up to and if not over 20 hours to fully charge it. The Samsung charger is an adaptive fast charger that only fast charges phones.
I use a QickCharge charger adapter
