Has anyone used an Anker power brick with one of the Bobby Backpacks? They have a USB cable that routes to the front strap where you can charge your phone. Great idea unless it doesn’t work, which is my case.
When I connect the backpack to the 26800 brick, the circle of LEDs on the 26800’s button stops and if I press the button the LEDs refuse to flash in a circle.
Does the 26800 have special USB ports on it that prevent it from working?
Thank you,
