Hi I have a PowerCore 20100. Only use for one long weekend camping an it now has a fault. It charges my phone for about 5mins then stops and I have to press the button to start charging again. The cable I have is an Anker iPhone cable and was purchased with the PowerCore. All the ports are clean and I have done a reset a couple of times by looping the charging cable from the input to output.
How long should I reset it for?
Are there any other things I can try before I contact support about the fault?
