Blockquote
professor
Lv15
Apr 5, 2020 12:07 pm:
I own this and recognise the problem. It is not full, it turns itself off having refused your substandard charging.
You have at least one problem.
- You need to use a 18W PD charger. You are not. You are charging from PC. Then,
- When do you use an actual 18W PD charger, you need to either a higher end cable stating it can handle 9V, or a short cable.
We assume you bought a PD Powercore, which costs more than a non-PD Powercore, because you have a PD device which benefits from 18W vs lower cost 10W, that device will have come with a PD charger. So use that charger.
Hi
Ok I don’t know the difference PD or non PD.
Bought this version for the oculus quest with anker thunderbolt.
I have the quest charger and also a samsung adaptive charger but I hear the samsung doesn’t ‘adapt’ correctly.
Already own a few anker cables which using to charge.
PC has now fully charged the PD,all lights on when button pressed,aso 1 green and 3 blue when long pressed button.
My mobo does have a specific usbC port so will look up its ‘charging’ supply.
Will check my oculus charger for info,when phone plugged in it does fast charger.
I also have the 20100 powercore (not usbC) which I tried to charge the PD with but same thing.
At this moment my problem/query is solved but I will deffo look into the charging options.
