PowerConf S3 mic not working with Win 10 over Bluetooth
Hi,
I cannot get the PowerConf S3 mic to work over Bluetooth with Win10. Unit software is up to date.
Win10 recognizes the unit as a headset (therefore with mic) but when trying to use the PowerConf with Teams, Zoom or Skype in the settings I can set the output to the speaker but when going in input setting the mic of the PowerConf is not a listed option…
Are other people experiencing this? Is there a workaround?
Note when connected via USB C I can then select the mic of the PowerConf.
Thank you
Same problem using Windows 10 with Teams/Skype.
Has this problem been resolved?
