Powerbank PowerIQ 2.0 backward compatibility
i bought this powerbank
Powerbank Anker PowerCore Select 20000 mAh A1363
when i use normal charger it takes a lot of time to fully charge it, and i read there is poweriq charger that makes it charge faster…
do you have suggestion what charger compatible with this powerbank? the specs says my powerbank uses poweriq 2.0 and use microusb port as input
if i use this wall charger, can it work?
Anker 511 Nano 3 Charger 30W PD PPS 25W
the wall charger use powerIQ 3.0 (which use newer tech than my powerbank)
1.) is it backward compatible? (with poweriq 2.0 powerbank)
2.) and it use usb c port, can i use regular usb c to micro usb to have the fast charging feature with my powerbank?
