Power Station 767 Display Faulty ?
hello guys i have a probably a defect in the display,
to be sure i will ask any of you guys if you have the same problem,
because Anker support says the following
"It has been confirmed that this is a screen design issue. " not a defect,
and i am here , on every review wit pictures and even YouTube reviews it don’t look like this
do anyone have the same problem with the display ?
because at some point i think Anker try to not to RMA the product and rather say
"Even sending you a replacement product will not change the situation. "
That’s the low temp high temp and overload section of the display. Try overloading to see if you can get it to light up.
I know it is , i told anker the same,
it is the warning sings and the littrly dont care,
They never mentioned to test or how to do a display test to see if warning lights work,
all they say production fault,
and dont want to rma it because of it,
to alot people i showed this pics they say a broken display becuase it have a fading cluster in the display
Look i dont like how anker support is, its the first time i encounter a probpem and asked support , i have alot anker products and this is the most expansive one i bought of them and to be treated like trash im disappointed
I just unboxed my brand new unit and can confirm, I have the same black box in the lower lefthand corner.
I just bought a new anker f2600 and i also noticed the same black rectangle on my screen in the bottom left corner and also in the middle of the screen. This is very frustrating as i spent a lot of money + bought expansion battery. Is there a way to fix it? What should I do now? As this doesn’t look normal to me.
![IMG_9570|281x500]
