Power port C1 device capability
Hi, I have a inquiry… does the power port C1 charge devices such as the iPad Air 2 and the iPhone 6 Plus and 6s plus as I have the power port C1 plug but I am thinking of purchasing a wire for it and just wanted to make sure. Thanks
PowerPort C1 is a 15W charger and should be able to charge the iPad Air 2 and iPhone 6,
You may use the Anker USB-C to Lighterning Black or White Cable
To answer your question, Yes for all three devices.
I’d go for the Powerline+ II (Type C - Lightning) with a lifetime warranty. The 3-foot cable will give you a slightly faster charge speed. More cable more internal cable resistance. The difference in charge speed is negligible. I’d go for the 6-foot depending on where you were going to use it.
15 watts is more than enough to charge all three of the devices listed.
https://www.amazon.com/Anker-Powerline-USB-C-Samsung-Galaxy/dp/B07JH9M4RS
Available in Red or Black, 3’ or 6’
AC_SY400
Okay thanks guys for the heads up, will purchase my cable now👍
