I was doing a test on my power port 2 and hooked both my android device and my ipad air into a meter and then into one port on the wall charger and I got an output of 2.68 amps. The Android alone was .95 and the ipad alone was 1.97.
I thought the max was 2.4 amps? Maybe the max is 4.8 if only using one port. Thoughts?
Power port 2 output question
Is this just IQ Voltageboost sniffing out the devices can ingest more (as you combined them)?
unfortunately I do not own a device that takes a charge at greater than 2 amps so I can’t test that. I have probably confused the charger as each device tells it what it needs but the charger doesn’t know I have paired two up and plugged into one port. I just thought it would only output 2.4 max form one port. I don’t think I will push it and make this common practice unless someone can tell me that it is safe for the charger.
If I recall correctly, the original 5-port charger had an issue where a port would become permanently disabled if the power draw exceeded 3 amps and tripped the fuse (they later replaced these fuses with a self-resetting circuit breaker). So I would assume each port can max out at 3 amps before the safety circuit kicks in.
Depends on how they have output to the 2 ports.
If i read it says 4.8A output, and it has 2 ports. So they may not have put a 2.4A limit on 1 port? Besides with the Voltageboost idea they are allowing to go above the USB limits to force through wire/socket resistance.
There is a tear down video of the Powerport 5 you see a fuse per port.
Powerport2: I’m wondering if they deliver the 4.8A to both ports and there is nothing to prevent 1 port going to 4.8A? Or they have a fuse per port but at some level >2.86A <4.8A?
I can’t see a teardown of the Powerport2.
I did this young chap’s review…
That’s awesome @TechnicallyWell a celebrity. I need to get me a second Drok meter also, if I had one I would not have run into my question.
Ha, far from a celebrity!
I seem to remember a device on Amazon that could test the full capabilities of a USB port, but I unfortunately can’t locate one now.
Is there a risk you explore the upper current limits and physically fail the unit in a non-warranty way?
Wouldn’t a tear down be more informative?
By the way, does anyone have pizza?
A tear down would be nice and if I had a couple extra chargers around I would enjoy doing that. I wish I had a couple devices that would draw enough current to push the limits, that would also be fun but again I don’t have spares lying around and I would miss my Anker if even just for a couple days if something goes
Can you smell the ?
