Power Draw - Retraction?
Is there a way to pull out of a power draw?
I entered the Eufy Smart Speaker draw rather excitedly before realising it was US only.
I won a US-Only draw previously and obviously didn’t get anything so I’d rather not let the same thing happen again…
That’s definitely a function the Power Draw could use!
But I don’t know if it’s possible. Maybe on admin level.
As far as I am aware the PowerDraw is a ‘read before entering, no refunds given’ thing…as essentially it’s not costing you anything physically except time to re-accumulate the bucks through posting.
Perhaps @AnkerOfficial can confirm?
I would contact Anker and see if it’s possible. But of course, do it as soon as you realize and not just before the drawing.
If possible (if you win) see if it can be sent to a US side address of someone on here and have it sent over to you. Not sure if it is worth the shipping depending on where you are at, but just a thought.
You could also ask, provided if you win, that they can send you something else that is available for your area. If I recall, they have done this for another member here in the past
You have won in the past ISTR, in Preston.
Send a message to @Ankerofficial and they will make you will make you whole. The problem I see is this is Saturday, after the winner selected.
I did the same.
But as it is just fun, I don’t mind to loose some “bucks”.
That’s life: Sometimes you loose, but sometimes you win.
Enjoy the sunday! :grin:
