Power Cube stopped working. There is a tiny hole says reset. What fits that? a pin? a certain needle side? a tool that was included I didn’t see or keep?
Id rather not have to throw it out if its not broken but got overloaded. And if it did get overloaded thats crappy design to make reset such a tiny whole , most powerstrips have an easy reset button.
Power Cube reset tool?
You could do it with a normal paper clip.
Should fit. better than a needle.
