Are all the compact portable power banks compatible with the iPhone 6 and newer iPhone models
Power bank compatability
Yes, would you like help deciding which to buy?
iPhone 6 and iPhone 7 will fast charge with any Anker power bank sporting PowerIQ on a USB-A (regular USB) port. That’s pretty much the entire line of currently available models.
iPhone 8 and later models also support the same fast charging standard. But they charge faster using USB-C Power Delivery. That requires a power bank with USB-C and 18W or better output. Anker has many models available, but it isn’t every model. The power banks with USB-C still support the PowerIQ tech for the older iPhones. So buying a USB-C model will work with an iPhone 6 today. And a future iPhone later.
Will work no problem.
