I just received the Portable Stereo Bluetooth Speaker. the instructions show 5 buttons on top.
Black on Black. Almost impossible to see. Maybe these buttons should be another color. So no matter how good the speaker is, if the buttons can’t be seen then how is this going to be operated?
I remember these can be touched and if you know the order of this buttons you can check these out by fumbling.
But sarcasm done…
Yes a little colour would be helpful.
This isn’t a bad idea at all. I think bright colors (like orange, red, purple, green etc.) would look ugly on these premium looking speakers. Perhaps a medium grey would look nice though?
Its matter of time, once you start using the speaker, you will get used to the button placement,
I have the Soundcore Icon mini and the buttons are same colored, and use the buttons frequently, without error.
If it helps, may be use a permanent marker (black, blue, red based on the color of the speaker you have ) or a colored sticker if it helps, – this is not a great idea but a workable one
A little coloured piece of a tape will do it too.
