Which Anker portable chargers will rapid charge a Google Pixel 2 XL, preferably using a USB-C to USB-C cable? Are any USB-IF certified? Thanks!
Pixel 2 XL -- rapid charge Power Bank options?
Hi @esirof, Glad that you’re interested in Anker products!
Unfortunately, your options for portable chargers that will rapidly charge a Google Pixel via USB-C are quite limited at the moment. Anker’s rollout of USB-C products has been dreadfully slow thus far.
Here are your best choices at the moment.
PowerCore 13400 Nintendo Switch Edition ($69.99)
PowerCore Speed 20100 PD ($99.99)
PowerCore+ 26800 PD ($119.99)
I would tell you to wait, but I’m not going to because I’ve been saying that for a couple years now, and look what waiting has done… Nothing.
So, with that being said… If none of the above strike your fancy, and you don’t want to wait (for possibly nothing), you may have to look at other brands’ selection.
