PD Labeling
I think Anker should label their PD Ports and PD Cables with the max power provided.
For Example, I often see PD labeled on their hardware and cables, but I need to know if I am connecting to a PD 60W port with only a PD 30W cable, then I might need a better cable depending on my use case.
Something like:
PD
30W
Interesting one @aheadnetworkmgmt
I only have 3 Anker chargers and they are all different in design so its not a problem for me.
But i know there are people that have multiple similar PowerPorts so i guess this could be useful.
The upcoming 5A PowerLine III USB-C does say “100W”
Its nice to see they are starting to label them :+1:
This is a good idea.
But you know, you never get that output which is labelled.
You can label Power but not cables.
