Pan and tilt control on Alexa Echo Show
Is there a way to control pan & tilt on the Alexa Show? I can zoom in a bit by tapping on the screen. But till now i have not found a way to control the movement.
Also i wonder if i can prevent the Echo to enter its startscreen after a few minutes.
I do have a pan and tilt but do not have the alexa show. (do have an echo dot but that will not help you).
You may have a better chance for answers by going to the Eufy community at https://communitysecurity.eufylife.com/chat
Definitely check the community link posted above. You could find more helpful info there
