Hello I just wanna know if it is possible to Pair a Flare and a Flare+ for Stereo sound. I want two speakers to use the stereo sound but it would be great to have a Flare+ to use mobile too so I wanted to know if it is possible to Pair Flare and Flare+ or just the same models with each other.
It is not possible to natively pair the two speakers for stereo mode…
However if you’re phone supports dual audio then you can connect two of them directly to your phone.
@Zensiert_Gamer @TechMan You actually couble pair Flare and Flare+ together for Stereo sound.
Is this something that’s been changed on a firmware update as I thought originally it was restricted to same models only?
