One Port On Anker Charger Stopped Working
Hey!
So ive had this charger less than 2 months and I took it on vacation with me. it worked perfectly fine, gets a full charge but one USB port just doesn’t omit a charge anymore. the other one on It works fine. any fixes??? thanks in advance
Care to share which charger you are talking about? If it was purchased 2 mo ths ago and you have issues reach out to support@Anker.com and they will be able to assist with troubleshooting and warranty exchange if needed
Take a look if there is any debris inside the plug and if the contacts are not bend. (Magnifier!)
Most.of Anker’s chargers have a breaker that will automatically reset if you unplug the unit for 10 minutes. Give that a try and if it still doesn’t work, reach out to support@anker.com and they’ll be happy to help you further!
Wonder what charger is/was giving you issues
