What is the maximum number of eufycam I could connect to one HomeBase?
Also, can I mix it up with eufycam E?
Hello!@min1 We’re glad to inform that a total of 8 HomeBases can be added on the same account, and one HomeBase unit supports up to 16 cameras and 16 sensors simultaneously at the current stage. Additionally, yes, the original eufyCam system can be used together with the eufyCam E series. You can simply add the eufyCam E in your eufy security app. Thank you!
