Notification Sounds on Pixel 3
Is there a way to set a different notification sound on an Android phone. I would like to know when the Cam sees something as opposed to other alerts?
This should work for ALL APPS…
Open the app
Go to settings
Scroll to notifications
Scroll to tune/sound
Change sound.
Don’t think you got the question
Some apps let you select a custom notification sound different to any other app
What you suggested changes the sound for all apps and the eufy security app still sounds the same as all of the apps
I do it for text, email, whatsapp so I know if any of those come through what it is before looking at my phone
I said quite clearly… Open THE app
THIS MEANS, OPEN EUFY APP, or whatever app you want to change. I really couldn’t have said it any clearer.
Eufy security app settings
No option for notifications, its been brought up a few times
Most apps don’t have a notification setting but this one should
