I’m having an issue with eufyCam and I can’t seem to figure it out. The problem I’m having is when recording is enabled, the homebase alarm and camera alarm will not sound. As long as recording is disabled, the alarms will sound without an issue. Push notifications work just fine.
I’ve already replaced a few cameras and even replaced the homebase and the problem persists. Is anyone else having this issue? It’s hard to believe that I can only choose one or the other but I’ve already replaced the cameras and homebase.
I’m using the eufyCam Security app on a Samsung S10+
Edit: Also just tried the app on an iPhone with the same issue. Everything works when recording is disabled. Once recording is enabled, alarms no longer go off.
