Hi all
I’ve just installed a door bell but the night quality seems really poor?
Ive tried changing the settings, turning night mode off but to no avail.
Would the attached be the quality I should expect?
Many thanks.
Hi all
Many thanks.
It might be because of a light very close to it. If I’m not wrong there might be a light on the left in that photo which could be the reason
That looks pretty bad, have you wiped the lense? Hopefully that helps a bit
