Newest PowerCore?
What is the newest version of the Powerbank Powercore High Capacity Portable Charger?
I am looking for any charger over 20000 mAh up to highest you have available.
I want to make sure I am ordering the newest one for my upcoming trip.
Please advise.
Depends whether power delivery is a requirement or not? The following chart shows the PowerCore’s which are suitable based on what you have mentioned, the newest being the PowerCore+ 26800 PD (Mar 2017) and Speed 2000 PD (mid 2017) respectively. If PD is not required you can save some cash by going for the non-PD models.
What type of trip?
PowerCore II 20000 is also very new. PowerCore Elite 20000 was released just before PowerCore+ 26800 PD.
I have the PowerCore 20000 PD, it works really well with my Macbook Pro and its charger on trips.
I would worry less about release date and more about compatibility. What devices will you be charging? If it’s just a bunch of micro-usb accessories (headphones, etc), then you don’t need any special power delivery variants, whereas if you have a newer Android phone or laptop, you might want USB-C PD for the fastest possible charging speeds. If you can tell us what you’ll use it with, we can tell you what the best fit might be.
Why are headphones so slow to adopt USB-C?
Feedback results from Anker’s polls (as per another @AnkerOfficial post) …but I agree USB-C options now need to be more seriously considered or implemented to keep pace…or perhaps to start setting the pace…with others
