New Release (Updated product) - Anker PowerCore 10000 Redux
No it won’t work because you cannot close the back.
Oh, now I get it. that sucks
Love the new material look on these
USA discount currently.
Besides size what is the difference between the PowerCore Redux and this PowerCore 10000 https://amzn.to/2EmAx0e
The redux is redesigned and has newer technology such as the new trickle charge function to fully charge low voltage devices that would normally turn it her battery packs off. So if you have Bluetooth Headphones the redux could fully charge them without it shutting off like the other one
I use PowerBeat 3 wireless headphones and never heard of the battery pack turning off while charging. Actually, that is the first time i’ve heard of that. I’m looking into a 10,000 charger to carry around daily as a iPhone X back up charger.
Redux is physically smaller and has a lower 12 watt output.
If fast charge is important to you I recommend the PowerCore II 10,00(18watt) or PowerCore II slim 10,000 (18watt)
Same as regular PowerCore 10000 though
True, but the Redux is more compact and pocket friendly :slight_smile:
Hope you’re having a good weekend bud
Thanks! I am, just busy…
If you’re cost sensitive then the regular 10000 is <$20 for next 4 hours.
The Redux is $26 currently.
The main difference is redux adds trickle charge which helps get to 100% charged smaller earbuds and it is physically smaller, it uses two thicker cells than the 3 thinner cells in the 10000.
As you said for its an iphone its hence a size vs cost issue.
