The hotter a battery gets above room temperature, the worse they perform.
The hotter a battery gets the faster it ages.
Wireless is less efficient than wired, but the gap is closing.
Inefficiency manifests as heat. So a wireless charger makes more heat. If you put a cell right next to that higher heat coming from wireless vs wired you worsen the cell.
When your energy to a wireless pad comes from a wall socket, there is no cell within the wireless charger, so the heat it experiences does not impact its aging or efficiency, but when your energy comes from cells within the wireless pad it does.
The production of the required DC is done external in a wired pad, while in a pad + cell combo the cell’s voltage which drops with capacity is buck-boost DC-DC converted within the same physical device so you have two sources of heat with a combined unit. A Powercore without a wireless pad only has the heat from the DC-DC conversion not also the wireless loop heat.
For these reasons, efficiency and aging, you’d expect for any given class of technology for a combined pad + portable charger to either die faster or be slower.
Of course technology improves, wired gets better, wireless gets better, but a combined product will always suffer from having to be that bit more of a compromise on Wattage.
Personally I think this heat issue would be better solved with a thermal regulator so you get a quicker charge first few minutes. That suits the pick-up/down usage style.
You see a similar related problem with the Powercore Fusion, the 18650 5000mAh cell in the same case with the AC/DC converter is why it’s so physically big and why it’s Wattage output is lower than chargers without cells within.
We discussed we saw these combined products as inevitable as for 10% cost increase, no size increase, no weight increase you can add a bit more usefulness. The issue is they didn’t do that.
I did my own efficiency calculation last month and I got a view 7.5W is viable so surprised its as low as 5W.
Of course you can make a less reliable product with higher Wattage, but then suffer the warranty issues. As @Tank showed, you can design around this via a more conducting outer case which spreads the heat from wireless over a greater area for more radiating or conducting dissipation.
So Anker can certainly make a better product, but it would cost more, but there is a truth independent on the designer that a combined product as it serves two masters, capacity and efficiency has to be worse than serving one.
I think this product will sell well, 12W is good enough for many phones, 5W is good enough for a portable charger, it will sell well like the Fusion sell well as it’s not the best at any one thing but it affords simplicity and that usually succeeds. I just think it needs more effort, they certainly can make its wired in+out when wireless not used at least 18W, they do that at low cost already and they can certainly make a higher initial cold wireless output which drops as temperature rises.
