Hi all,
Well, I did it. I bought a new Macbook pro 16. Now that @professor has lost all respect for me, I’m curious about battery health and what sort of charger is best for prolonging the battery life in this new, perhaps overly expensive, laptop. To be fair, I need to edit video and run some fairly processor- and graphics- intensive creative software on the go these days, which was the reasoning for moving away from my beloved chromebook in the first place. Here’s the setup :
SO - here are my questions. I should state the factory charger is a whopping 96W:
Is it advisable to routinely use a lower wattage charger (ie. Atom III Slim or PowerPort Strip PD 2) for the battery in this machine? As far as I know, it’s not going to hurt the battery to ingest a lower wattage, but the charge will take longer. I don’t really mind the charge taking longer.
Should I avoid fully charging or depleting the battery? This article says that
“Going from 100% to 50% charge is half a cycle. Yet how the batteries actually work from a chemistry and physical perspective means that this puts less of a strain on battery life than going from 100% to 0% all the time.”
Another article advises
“Routinely unplug your laptop, as frequently as daily, and let it drop its power down to the 30 to 40 percent range.”
Also, it points out that
“careful charging past about 80 percent capacity. After that point, it’s easy for the batteries to overheat, which can damage them or, in the worst case, cause bulging or even fires. That’s why battery circuitry on all devices throttles charging speed from 80 to 100 percent.”
When I put these two things together it seems like the best strategy is to actually use a lower wattage charger that will power the laptop while I work on it and slowly recharge the battery so that I stay between 30 and 80%. For those that know more about this than I do, does this make sense?
Is there any reason I should avoid using power banks to recharge while traveling?
What’s the best Anker product to replace the factory charger if I find it too bulky? I’m torn between the Atom III Slim and the PowerPort Atom PD 4, which, as far as I can tell, is the only Anker product would actually provide a full speed charge (as long as nothing else was plugged in
Thanks is advance!
