New Customer(PowerCore15600) charger particularly hot?
So I scoured the internet looking for a new power bank and it is the first one I have ever purchased for myself. It came with only a usb cable to charge it, no wall mount piece. I used a samsung wall mount that I would use for my cellphone and noticed 3 hours later how crazy hot it was (can smell warm plastic but not burn your hand). I figure if it is that intense they would provide the wall connector? Is this normal or do I need to purchase a specific type/are there good and bad ones in a typical household? Thanks for the help!
EDIT: the phone block i plug into the wall connected to the Anker USB cord that was provided came with my Galaxy Note 8.
Try using a different cable for charging
Also since you say it’s getting too hot, I don’t recommend you using it and contact support@anker.com
I second @Shenoy
Stop using n contact support.
Stating … Where you ordered n order number.
plus serial number off box / cable.
Danger!!!
No more use please.
Contact the support
support@anker.com
Or do a call.
You find the phone number for your country at the support site.
Good luck.
Yes return that one. Get another. Anker will replace for sure.
if you can smell plastic its possibly not a good sign :mask:
Let us know how the return goes!
