Need Recommendation - iPhone 11 and Galaxy S9
I’m trying to find a charger that will fast charge both my partners iPhone 11 and my Galaxy S9. I know they’re two different fast charging specs and I’m hoping Anker makes a charger that supports both.
If not, are there two different smaller surge protectors that support Quick Charge 3.0 and USB Power Delivery. We could live with that.
Hi @Skip5, Anker’s PowerPort III Duo is a perfect solution for you!
PowerIQ 3.0 supports both Power Delivery and Quick Charge!
Hope this helps, and feel free to reach out with any further questions. :slightly_smiling_face:
Looking at this it appears only one port supports your PowerIQ 3.0 spec, while the other is 2.0. If I understand it correctly that means only the device in the 3.0 port is going to receive the quick charge. I was hoping to be able to quick charge both simultaneously.
Nope, both are PowerIQ 3.0, and you can fast charge simultaneously!
Does the PowerPort Atom III Slim also support Power IQ 3.0 on all ports?
I think it only has 1 port
If you mean the four-port version, no–just one.
