Hi all,
Could somebody help me to get the right charger …
Want to charge following devices (with one charger at the same time):
- iPad Pro 11“
- iPhone 6s
- iPhone 7
- Apple Watch
Thanks in advance !
T.
Hi all,
Thanks in advance !
T.
If you’re looking for a power bank aka portable charger:
The USB-C port will fast charge the iPad Pro. If it is older than 2018 then you’ll also need a USB-C to Lightning cable.
The USB-A port will fast charge the iPhones. Those iPhones support an older Apple fast charging standard: Apple 2.4A. That is on the USB-A port of both power banks. You could charge the iPad and an iPhone together. The Apple Watch has no fast charging support, so charges normally with USB-A.
If you don’t care about fast charging then any Anker power bank will get the job done.
If you plan to support all four devices you’ll want a larger power bank. A 20,000mAh would give them all 1 recharge. A 26,800mAh is the largest you can take on all USA flights (some airlines allow larger batteries).
If you’re looking for a wall charger you’ll be best off with a multi-port charger that offered one USB-C and one or more USB-A. Anker PowerPort II PD is great for travel. Anker PowerPort Speed PD 5 could charge all your devices at once.
Thanks a lot
