Does anyone know the code number needed to pair the Nebula Soundbar to a UK Sky Q remote control?. TIA👍
Nebula Sounbar
Hi @david.greatrix which model of soundbar do you have, namely is it a model with HDMI support to allow control?
It’s the Nebula Soundbar with 4K Fire TV from Amazon
Thanks. Provided you have connected the Soundbar to TV by HDMI ARC connection, you should be able to adjust the soundbar volume as you adjust the TV volume (though you may need to reset your Sky Q remote).
