Hello! First post but I have just bought a Nebula Solar Portable and had some questions.
I am struggling with a key feature of the projector for me - being able to play mp4s/m4vs direct from a USB drive (I do not want to cast/stream). I use my projector when I go camping (in the UK), where there is no phone signal so its really important that I can use a USB with movie files on it as my primary use.
None of my USB drives/sticks appear to be compatible with the Nebula, although they are FAT32. So I tried a work around and put a blank USB into the Nebula and then formatted it through the projector. Result was that USB drive is then not readable either on my OSX Mac or my Windows 10 PC to copy files onto - slightly annoying! My drives are all around 32/64/128GB in size, could that be the issue and I need to only use 4/8/16GB drives?
Can anyone also advise the software to browse the USB - at the moment all I can do is highlight the notifications to access the drive, which only gives me the options of Browse, Eject and Format (note Browse does not allow me to see the contents of the USB).
In another thread I saw someone recommend ES File Explorer - as far as I can see that is not available on the UK Play Store. Is there an alternative?
Finally, is it possible to copy movie files directly onto the projector - I think it has a small amount of storage internally? I did try Android File Transfer to do this but it didn’t want to connect.
Sorry for so many questions, but I need to use my projector “off grid” mostly. Not really interested in casting or streaming. Any help much appreciated!
