Nebula Anker Nebula Solar Portable 1080p Projector, Dolby Digital Plus, 2x3W Speaker, Android TV, Built-In Stand, Autofocus, 3-Hour Battery Life, Keystone Correction, and Digital Zoom
Save $40 with introductory offer
Buy here
- Cinematic Visuals: Experience up to 120 inches of awesome 1080p entertainment. With HDR10 and 400 ANSI lumens also included, everything you watch and play is packed full of rich detail and color.
- Unforgettable Audio: Hear every whisper, explosion, and song in incredible clarity with Dolby Digital Plus and the dual 3W speakers. The sound is so powerful and clear that you can even use Solar as a portable Bluetooth speaker.
- No Wires, No Limits: With Solar Portable 1080p projector’s built-in rechargeable battery, you can recreate the sights and sounds of the cinema anywhere you want. Get up to 3 hours of power on a single charge—more than enough to mini-binge your favorite TV series.
- Entertainment Tailored to You: Choose from more than 5,000 apps with Android TV 9, including favorites like YouTube, Hulu, and more. You can even mirror content from your smartphone or other devices to Solar Portable 1080p projector.
- Easy to Adjust: Leave that heavy tripod at home. Use Solar Portable 1080p projector’s built-in stand to adjust the angle of projection by up to 13 degrees.
Focus Without the Fuss
Jump straight into the action without the need to fiddle with settings menus thanks to Solar’s ultra-fast autofocus. Simply switch on the projector and Solar will handle the rest.
Brilliant Blacks, Incredible Colors
See your movies, games, and more in an all new light with HDR10. Colors are radiant and bright, while blacks are deeper and darker for enhanced contrast and detail.
Suitable for Any Surface
Solar’s quadrilateral keystoning ensures that you get a perfectly squared image on almost any surface.|
Form Meets Function
There’s more to Solar’s sleek looks than meets the eye. Adjust the angle of Solar’s image by up to 13° with the built-in stand—there’s no need to carry about a heavy tripod.
Big, Small, or Anywhere In Between
Adjust Solar’s picture to suit any situation. Max out the image at 120 inches to catch the big game with friends, or scale things down for an intimate movie night for two.
Versatile Connections
Connect up your HDMI and USB devices to play your favorite media on the big screen, or wirelessly cast content to Solar via Airplay, Miracast, or Bluetooth.|
Product description
Model Number: D2131
Color: White
What’s In The Box: Nebula Solar Portable, remote, quick start guide, PD charger, USB-C to USB-C cable, 12-month warranty, and our friendly customer service.
Note: Remote required to use the Google Assistant.
Size
Length: 192.25 mm / 7.6 in
Width: 192 mm / 7.6 in
Height: 58.65 mm / 2.3 in
Weight: 1.4 kg / 49.4 oz
Display
Display Technology: 0.23DMD in 1080p DLP
Native Resolution: 1920x1080
Brightness: 400 ANSI lumens
LED Life: 30,000 hours
Aspect Ratio: 16: 9
Throw Ratio: 120 in @3.18 m; 100 in @2.66 m; 80 in @2.12 m; 60 in @1.6 m; 40 in @1.06 m
Offset: 100%
Focus Adjustment: 3-second autofocus
Projection Mode: Front / Rear / Front Ceiling / Rear Ceiling
Keystone Correction: Auto (vertical ±40°) Manual (horizontal ±40°, Quadrilateral ±40°)
Interface
HDMI: HDMI 2.0 up to 4K input
USB-A: For USB flash drives
Type-C: Power Delivery charging
Control
Physical Buttons: Power
Touch Buttons:Volume± ,Mode Switch (Bluetooth speaker power)
IR/BT Remote: Power / Autofocus / Google Assistant / Up / Down / Left / Right / OK / Back / Home / Setting / Volume±
BT Remote App: Nebula Connect for Android & iOS
Hardware
CPU: Quad Core A55 Chipset
GPU: Quad Core Mali G31
RAM: 2GB DDR
ROM: 8GB eMMC
Battery: 20,000mAh / 3.7v
Speaker: 2Ă—3W
Wi-Fi: 802.11a/b/g/n/ac
Dual Frequency 2.4/5GHz
Bluetooth: BT4.2 Dual Mode/A2DP
Fan: <30dB
Software
OS: Android TV 9.0
Google Assistant: Supported
Chromecast: Supported
Working Modes: Projector Mode, Bluetooth Speaker Mode
OTA: Supported
App Store: Google Play
Video Playtime: 3 hours
Charging Time: 3 hours with Power Delivery 20V-3.25A
Audio Decode: Dolby supported
Audio Formats: Supports MP3, WMA, RM, FLAC, Ogg
Video Decode: HDR10
Video Formats: Supports .mkv,.wmv, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm formats
