Nebula Prizm II Price Drop - Deal $159.99
Nebula Prizm II price drop deal for $159.99 - no code needed.
Nebula Prizm II
About Nebula
Nebula is the pioneer of immersive entertainment. Nebula’s vision is to give you an advanced visual and interactive experience at home and beyond.
Nebula is a brand under Anker Innovations Ltd.
Designed to make premium entertainment experiences accessible to all, Nebula Prizm II provides a huge picture, balanced sound, and easy setup.
  • 200 ANSI lm
  • Dual 5W Audio Drivers
  • 1920x1080
  • 30,000-Hour LED Lamp
  • Multiple Connection Options
  • Extra-Quiet Cooling Fan
  • Horizontal & Vertical Keystone Correction (±40°)
High Definition Enjoyment
Play your favorite films, shows, games, apps or even music in an awe-inspiring 1080p Full HD picture.
Dazzle with Dust-proof Durability
Prizm II is built to last, incorporating tactile fabric and premium materials that look good, and feel solid.
Lighting Longevity
Watch a 3-hour movie every day for 27 years.
Cinematic Sound
Breathtaking bass sound heightens those climatic movie moments.
Extensive Connectivity
Enjoy near-limitless entertainment by connecting your USB or HDMI device.
Make the World Your Screen
Horizontal and vertical keystoning ensures a sharp, stable image—no matter the surface.
Description
Technical Specs
Brightness: 200 ANSI lm
Resolution: 1920 x 1080
Projection Image Size: 40–120 inches
Display Technology: 5.2 inch LCD
Light Source: LED
Contrast Ratio: 1500 : 1
Throw Ratio: 1.4
Projection Distance: 3ft - 12ft
Projection Ratio: 30 inches at 3 ft; 60 inches at 6 ft; 80 inches at 8 ft
Keystone Correction: Horizontal and Vertical (±40°)
Audio Driver: 2 × 5W
Connectivity: HDMI 1.4, USB, AUX-Out
Recommended Operating Temperature: 14°F to 95°F
Relative Humidity: 15%–85% (non-condensing)
Power Supply: DC 19V
Power Consumption: <125W
Remote Control Batteries: 2 AAA batteries
Storage Temperature and Humidity: -4°F to 149°F, < 90% humidity
Dimensions (L × W × H): 10.98 × 10.43 × 3.81 in
Weight: 85.4 oz
Video Formats: H.264 BP / MP / HP – up to 1080p MPEG-4 SP / ASP – up to 1080p DivX 4 x / 5 x / 6 x – up to 1080p H.263 P0 – WVGA VP8 – 1080p (HEVC) H.265 MP 8-bit – up to 1080p
Screw: M4
Spacing Between Screw Mountings: 5.2 × 4.6 in
Adapter: 6.3 × 3.0 × 1.0 in
What You Get: Nebula Prizm II, power adapter, cable, remote control, user manual, worry-free 12-month warranty, and our friendly customer service.
*Does not support content-mirroring of copyrighted materials on Android and iOS devices.
Usage Tips:
•Use in low-light environments for best results.
•Not recommended for PowerPoint, Word, Excel, or business presentations.
•To minimize the risk of overheating, turn off after 3-4 hours of continuous usage.
•Dolby sound is not supported. If there is no sound with the picture, turn off Dolby Digital support in your Apple TV, Blu-Ray player, Fire TV, etc device.
Features & details
  • Full HD Picture: Place in virtually any room to enhance your favorite shows or movies with a native full HD 1080p 40"-120" picture. (Recommended for use in low-light environments).
  • Built-In Speaker: Dual drivers deliver balanced audio through left and right speaker grilles, pumping out a deep, immersive bass sound.
  • Keystone Correction: Horizontal and vertical (±40°) adjustment ensures a clear picture from any distance or angle.
  • Comprehensive Compatibility: Connect almost any device including Fire TV Stick, Chromecast, Roku, Xbox, and PS4 via HDMI or USB Lightning cable.
  • Durable Design: A UL certified power supply and a 30,000-hour LED lamp-life ensures that you can enjoy decades of worry-free entertainment.
Great deal, thanks for sharing. :+1:
@Shenoy what was the original price before the price drop
It was $239.99 until the earlier deal expired
Great deal, thanks for sharing @Shenoy
great deal! :ok_hand:
I will create another photo montage soon…
May I use the old one meanwhile?
sherlock
I have the Prizm (1 or Original) - not blown away by the quality. Not sure I can justify the 2 just yet.
Maybe save up for the capsule or other higher end projectors.
I bought 2 of Prizm Original for $40 bucks each when I published the deal, one for us and other for my brother. Used up all of my Amazon GC balance :joy:
Have used the Prizm couple of times, so far so good, will write a review soon
Have you ceiling mounted it or place it upright?
I might take a few days break from deals :rofl: unless there are really great enticing deals and be a lurker for some time :stuck_out_tongue_winking_eye:
