Nebula II Bluetooth with HDMI
When viewing through streaming apps, the sound plays through the Bluetooth speakers, but when using HDMI (Blu-ray player) sound plays through the projector.
How can I get sound via Bluetooth in HDMI mode?
I would contact Anker support for an answer, it may not be capable of performing that function, I’m not sure if it is or isn’t because I am not very knowledgeable about this device. If it can’t do it you may be able to use a bluetooth transmitter through the aux.
You would need a Bluetooth transmitter connected directly to your Blu-ray player and paired with a Bluetooth speaker otherwise the sound is just going to play from the projector. It does not have the ability to send over Bluetooth from the HDMI port sorry bud.
AC_SY400
https://www.amazon.com/Anker-Soundsync-Transmitter-Synchronization-Connection/dp/B07BR3FFTB/ref=mp_s_a_1_4?keywords=anker+bluetooth+receiver&qid=1564286611&s=gateway&sprefix=anker+blue&sr=8-4
Have you checked the settings?
