Hi there
I bought a nebula cosmos yesterday on a amazon prime deal. I got it set up fairly easily and watched it for about an hour thinking it was pretty decent.
It then suggested a firmware update and since that I have the following issues
Won’t now turn on via remote only by pressing the button on the back of the unit (annoying as it’s mounted on a shelf quite high up).
I only only get possibly 5 seconds of the home screen before the picture goes blank. The unit is still on and whirling away but no light from the lense or picture.
Nothing I press on the remote works or makes any difference except it will turn off.
This is obviously not right and i need to find out what to do to sort it out before I loose faith in it and return it to amazon for a refund (still a favourite option I think)
Very frustrated / annoyed at present
Any help would be appreciated
Thanks in advance
Ben
