Nebula Capsule 2 or Capsule Max
Hi there,
Please be noted that Capsule 2 and Capsule Max have the same image and sound quality. But Capsule Max charges through AC charger with 15V/3A or 19V/2A. Capsule 2 needs to be charged through PD charger which is capable of 30W. Standard 5V/2.4A USB charger might not work well.
Thank you!
Anker Support Team
thanks for answering all these questions, one final one I have is the Capsule Max capable of charging while projecting?
I have the Capsule (not Max), and this can be charged while it is projecting. Should be the same for Max.
I had the Max and yes it can be charged while using, the Max had non-USB barrel charger type.
Note that does mean it recharges fast but also means it cannot be powered from a typical portable charger, although we suspect a USB 5V step-up cable would probably work.
Hello!
I just acquired the Capsule max.
Has anyone tested the USB 5V step-up cable to load the device from a USB charger?
Would loading it that way damage it or would loading just be slower?
Thank you
Regards
Here is the summarize differences I found between the CAPSULE II ----- MAX
Charger : USB-C ---- AC
CPU : Amlogic S905X (4 cores, 64-bit) ---- Octa-Core A53 Chipset
GPU : Quad Core Mali 450 ---- Adreno™ 506
ROM : 8GB ---- 16GB
OS : Android TV 9.0 ---- Android 8.1
BLUETOOTH: 4.0 ---- 4.2
Extra: includes chromecast ---- includes horizontal keystone
Question - based on the above do you find the USB-C/Chormcast more/less important than horizontal keystone
