After charging the Apollo for a short while, like 30 to 45 minutes, the charging indicator quickly turns from red to green. What does the green status mean? I think green doesn’t mean that the unit is fully charged. I can see this in the battery indicator in the task bar of apps when I turn the projector on.
Is the battery indicator supposed to turn itself off after a full charge?
I ask because the battery LED indicator still shows green and the unit feels slightly warm after 5 to 6 hours of charging. Should I wait for the green light to go off if I want a FULL charge? Does the indicator even turn itself off after the battery is fully charged?
I’m worried if I keep it plugged in, the battery would overcharge.
Any help is appreciated. Thanks.
