I was contacted by Mynt to see if I wanted to test out their Mynt Cordless Shiatsu Massage Pillow with Heat. And of course, I jumped at the chance. It couldn’t have come at a better time too. So here is my opinion on it.
Features
- Dimensions : 13.5 x 9 x 5"
- Weight : 3lbs 1.1oz
- Battery : Lithium Ion
Comes with …
- wall charger
- owner’s manual & warranty information
Pros :
- Easy to use … 1 button ON/OFF (long press) … 1 long press
- Option for Heat … after turning on, press one more time to activate heat
- 15 minute timer … when time is up, unit shuts off
- Love the color combo … Ash gray with light gray, blends together nicely
- Good quality fabric … strong, mesh is thick
- Perfect for IT Band, legs, back, neck, and even arm
- Great for my IT Band. I always have very tight IT Bands that I use a roller on. With this, I can sit down and let the massager do the work for me. I especially love that the nodes of the massager, it switches directions after a few minutes. This really helps to loosen it up.
- You don’t have to physically hold it to you… unlike those handheld massagers
- Helps with my wrist pain from being on my computer all day … loosens that baby up
- Provides a deep massage … be warned, it can hurt at times. But no pain, no gain.
- Nodes switches directions to really work out the kinks
- It’s rechargeable … can be used anywhere … I like to use it while I’m watching tv
Cons :
- When using heat, it reduces the battery life … I only use the heat when I really need to
- Since it uses a rechargeable battery, you can only get up to 1 hour of massage before needing to charge again.
Overall, the massager is made of high quality material. Compared to a similar massager found at Brookstones, it just looks better and feels better. The charging cable can be a bit hard to plug in but I think that’s better then being loose. Charging port can be shoved into the pocket in the back to hide it when not charging. It takes about an hour to charge up.
As I stated earlier, I tend to have very tight IT Band and legs. I’ve invested in so many gadgets to help me with it, and yes, I do stretches too. I have rollers, electro stimulation machine, rechargeable and plug in massagers but I can honestly say that the Mynt has helped me with little effort on my part. I don’t need to be holding and pressing the massager to myself, I can just sit down in my armchair, put it under my leg or IT area and relax while it loosens it for me. I’m not going to lie, at times, it hurts and almost brings me to tears as it gets deep into my muscles. Of course, if you’re just using it relax, it shouldn’t be painful at all. It only hurts when you’re tight and round up like a Jack in the Box. Hahaha. But afterwards, I am more relaxed. And the fact that it’s uses a rechargeable battery is awesome. I can use it anywhere. No looking for a nearby outlet or having to use an extension cord to plug it into.
So who is this massager good for? Anyone and everyone that has back pain, leg pain, or just needs a little pampering. Being able to use it anywhere is priceless. And the surprising thing is … it cost a whole lot less then places like Brookstone for their version. At the time of this review, this Mynt massager is $49.99. Brookstone’s version is at least 2 times that!!! I would highly recommend this massager.
Purchasing link: Mynt Cordless Shiatsu Massage Pillow
