This little speaker is a dream wonder all in its own. It is small, robust and packs a decent punch. Sure one speaker by itself isn’t as loud as I would like it, but when two are paired together it gets really loud and you can position them for that stereo sound. In my brief video I demonstrate the speaker in and around my swimming pool, sorry the pool isn’t all sparkly as I am just setting it up for spring/summer.
This speaker is made of metal, has a metal upper body and the lower 1/4 is rubberized. On this rubberized part you will find the power button, a volume up and down, A play/pause button, and the bluetooth button for fast easy pairing. I tested only 1 speaker for a week, and just yesterday I got the second speaker to test them in stereo. Now one speaker is loud, but not loud enough for me…but given its size I cannot complain as its plenty loud when its right next to you. When paired together, the speaker seemingly comes to live with a monstrous roar…yes i am exaggerating a bit but it gets really loud and I can hear it decently as I walk away from the two speakers a considerable distance. If one was so inclined to use both speakers at a different location instead of together, they will remain paired up to about 68 feet and then they start disconnecting from one another. As you can see in the picture I had one speaker next to me and the other I had all the way at the end of the aisle which was almost 70 ft away, now this is direct line of sight so you may experience disconnects when trying to pair through walls.
I did test the distance while I was at work and given the environment I work in, these speakers did an amazing job filling such an open space with music and granted the bass is a bit lacking, it is notably present in some songs and isnt muffled at all.
The second speaker is on the box on the cart…its just a tiny black speck, lol
Here are the rest of the pictures I took as well as my video of the speaker I didnt do a time lapse of the speaker being in the pool for 20 minutes but I did have it in there. the water was just too cold for me to keep putting my hand all the way in to check on it. I also did a few dunk/splash test when I first put it in the water. Let me know what you think…Again sorry for the dirty pool, my glasses are transition so they tint on their own, and Im sick so again I apologize
