Soundcore’s Life NCs are in one word, amazing! Honestly, I never thought a tiny speaker could produce such a variety of sound while having an Active Noise Cancelling component, there just doesn’t seem to be room for all that tech in such a small device. Here I sit, blown away again by Anker, thanks!
Pros: Great sound quality and range of sound from High, Mids and Lows you can hear it all.
Small profile, Long battery life (even with ANC on), and the ability to change from ANC (Active noise cancellation) to Normal and possibly my favorite new feature, Transparency, which allows you to change the sound mode so that even while wearing both earbuds you can hear the outside world just fine.
They also come with a Travel Bag that will fit them as well as hold any cables or charging bricks you may want to bring along. Although the best part about it is the little zipper pocket inside to hold the extra ear bud pieces that change the size, as well as the Aux Cable they come wth.
The Aux Cable. Anker has made a cable that plugs into the micro usb charging port in the headphones and the other end is auxiliary for either just generally saving battery or if you want to use them on an airplane or other places where bluetooth may not be allowed.
Cons: It is difficult to find fault with these headphones, it really is, so I will be picky…I wish they had made them so the earbuds would have a magnetic attachment to the ends of the neckband instead of just to each other. The first pair of Bluetooth earbuds I ever owned had this feature and I have to say it is a great way to store them when you are not using them but still wearing them or only using one.
Overall: Highly recommended if someone is looking for new earbuds. The range and quality of sound is impressive along with the extras you get, Travel Bag, Aux Cable. It is important to me to stress how good the sound really is compared to any of their other earbuds, it really does blow them away. The tones are not as deep as over the ear headphones, but close and that is saying something when you take into account the difference in the size of the speakers in the two.
P.S: I recieved my T-shirt the other day! It is awesome, love the design and it fits perfectly!
