My Soundcore Liberty Air 2 disconnect approximately 1 hour after starting a meeting or call
For some reason when on a videocall in my Macbook, or a call on my phone (Pixel 4), after ~1hour suddenly the sound switches to my computer/phone, even if the Bluetooth settings say that the earbuds are still connected.
I already reset the earbuds following Anker’s tutorial on youtube, and I still have the issue?
Has anyone had this issue and found a way to solve it?
  • Forget the pairing record on your device and turn off the Bluetooth on your device
  • Place the earbuds into the charging case and make sure they are being charged.
  • Press and hold the button on both earbuds for 3 seconds. The LED indicators will flash red 3 times and then turn white.
  • Close the charging case, wait for several minutes and then take them out of the charging case, the white light on one side will flash quickly, which means it enters pairing mode
  • Enable the Bluetooth on your phone. You can find the device name "Soundcore Life P2 " or “Soundcore Life P2-L” on the Bluetooth list.
  • Please click "Soundcore Life P2 " or “Soundcore Life P2-L” for pairing, the white light will flash slowly, which means it paired successfully.
  • Then there will pop out a screen with “Bluetooth Pairing Request”, just click “Pair” (this step is very important)
Please note, due to the chips platform’s compatibility, in the bluetooth pairing list the Soundcore Life P2 is displayed as “connected”, and the Soundcore Life P2-L is displayed as “not connected”. In fact, the earbuds are normally TWS paired to work.
