My SoundCore 2 stopped connecting Bluetooth. When I was trying to connect my soundcore 2, its keep dropping and the bluetooth blue light blinking. Any leads how to fix it? IS there any firmware update needs to be done? Please advise
My SoundCore 2 stopped connecting Bluetooth, Any leads how to fix it?
Try a reset
Thanks for sharing a tip. Tried and It doesn’t help. Any other solution?
Please help.
How old is it? I’d advise to contact support
Its just less than an year old.
Please contact soundcore support at the earliest, service@soundcore.com
They may help with fixing it or possibly replace it based on the warranty details
I wish you luck in your journey and contact support
