I’ve had my Soundbuds Slim earbuds for about two months and today they stopped connecting. They say they’re connected but I get no sound.
My Soundbuds Slim stopped connecting
On your phone, try “forgetting” the SoundBuds slim and then re-pair them to the phone. If the issue persists, please reach out to the support team at support@anker.com. Thanks!
- Fully charge the earbuds
- “Forget” the headphones in your device’s Bluetooth history and reset the earbuds by pressing Play Button & volume “+” for 5s when plugged into charging until you see the purple light two times, and then pair them again to test at the paired state
-Try pairing the Anker headphone with another Bluetooth device.
If the issue still persists, don’t worry, please don’t hesitate to contact us at support@anker.com by detailing your order number and the problem you come across. We will reply you within 24 hours.
One year later!
