Hi I’m cordova and have been using the Powerline+II for about two weeks now.
Im gonna go over the cons and pros to this product and give a little bit of why i like it.
The package is very useful and the cable in it is normal compared to most anker products but what sets it apart from other companys cables, it has a carrying case. While some consider this unessecary i feel like its a good way to bring it with you without ruining the cables filament or exterior.
Pros.
-Free carrying case
-very cheap for what your getting
-6ft?!?!
-visually appealing and strong
-MFI certified.
Cons.
-There
-Are
-None
But honestly there really isn’t. I have never had problems with charging speeds or tears in the cord thanks to the nylon brading. Its also cheaper than the stock iPhone cable which comes in at $19 usd while the powerline is only $17.97.
So it comes down to the point.
If you want a cheap cord while stile receiving the same or even more strength of a normal cable then its for you.
