I have been using the fusion for around 4 days and I am already in love with it.
From the usb-c port to the usb-a its versatile and portable.
If you read reviews on amazon they say its a brick but I can confirm it isn’t much bigger than a powercore 13000 so its pretty reasonable sized for what its doing for you.
So some Pros to it are.
1.Portable
2.High Capacity
3.Usb-c Port
And some Cons
1.No charging the battery’s from an external source besides the wall
2.Limited things that you are able to charge at one time(no major deal though)
In my opinion the fusion 10k’s Pros really outweigh the Cons and i would recommend it to anyone that is looking for a reasonable priced and Outstanding performance battery pack.
If you have any questions just ask and il be sure to get back to you
-Cordova
