My power line charger broke what do I do
The tip of my anker charger broke and I think it’s under warranty what do I do
@gwstarkey.gws May be a picture would help. As a health & safety issue (to avoid any short-circuit / electrical shock while using) , I would advice not to use the charger, try alternate chargers
Contact Anker Support support@anker.com for warranty
Best of luck!
I don’t think it would be hazardous or for that matter the tip is separate from the cord so I don’t think I’ll be using that charger any time soon :sweat_smile:
It is better safe than sorry :wink: you are the better judge of how bad / good the equipment is!
Is it Anker Powerline Cable or Anker PowerPort Charger adapter?
It’s the tip that goes into the phone
Hey @gwstarkey.gws
If it’s under warranty you have two options really.
Either get your retailer to exchange it or as @Shenoy has mentioned get a photo or screen grab of your receipt and make contact with support.
Hope Anker replaces it for you
So as it turns out I can’t replace it so I will just get the powerline+ iii
Did the Anker support reply back?
That’s a pretty good choice
Yes but lost the proof of purchase :disappointed:
Where did you purchase it. Amazon, Walmart, target?
I picked it up at Walmart
