A comprehensive daily use basis experience by an user
Let me start this review like others, saying: My experience is unbiased and is based in my use for almost 4 weeks, I’m not attached to Anker nor have received payment for describe my use of this product.
Said that, let’s start with the review…
The first thing that captured my eyes is the polished texture of the charging case, also this is smaller, before opening the case and discover that the new earbuds are also smaller (which I said with the previous versions that should enhance).
The box like always is soft to my hands, I always love touching the Anker packaging boxes, could sound strange but that is part of the details, Anker focus on little details like these.
The battery
When talking about battery, it is very long lasting, having the case also gives you a lot of time because any second you put the earbud inside the case it will start to charge, so it is like having an infinite power. Also charging the case doesn’t take that much, specially if you are charging it using an Anker charger with PowerIQ.
The quality of sound
I have other sound core liberty air which I still use, but the Liberty Neo sound quality has been clearly enhanced compared to my other earphones. When the music has bass, it will give all bass, when you need a clear sound, it will be clear because seems the material used to make this are perfectly selected.
The package
Inside the package (which I love a lot) you’ll find a lot of replacement and adjustable rubbers for fitting the earbuds to your ears, also an USB cable is provided, the user guide, and so on.
Overall Impressions
I think Anker upgraded this gadget very well, compared to previous versions of the Liberty Air this upgrade comes in a good time, specially with all these music subscriptions and Streaming services, you will need more power and more time to enjoy your content, so having a earphones with more power, more quality and more durability is a must.
My overall score for this is 9/10 (score based on quality, size and price)
If you have any comment, don’t forget to leave it in the comment section below.
